Nwe Koni adjustable shocks
Old Mar 7, 2004 | 03:32 PM
rarfinacial's Avatar
rarfinacial
Default New Koni adjustable shocks
I lowered my car before the install, It was the perfect hight for me and now after the install the car is back to the stock hight. The Koni's have eight adjusting levels from 1 to 8, I set mine to #5 . The ride is nice and tight, feels great. Could it be that the #5 position on the Koni's is much to stong and not letting the car settle? Please Help...(the spring bolts are at the lowest spot without cutting the rubber)
[Modified by rarfinacial, 8:56 PM 3/7/2004]
[Modified by rarfinacial, 10:04 PM 3/7/2004]
Old Mar 9, 2004 | 11:12 PM
JakeL's Avatar
JakeL
Default Re: New Koni adjustable shocks (rarfinacial)
I experienced this too.
the reason the car is higher is because the nitrogen pressure inside the Konis is much higher than in your stock shocks. There's nothing you can do about it, unfortunately.
My front was low enough, but I bought longer bolts from A&A in the rear to get the car a bit lower there.
Enjoy your new shocks!
-Jake
