PFC-Z Brake pad replacement question??
Old Mar 9, 2004 | 05:13 PM
TedDBere's Avatar
TedDBere
Default PFC-Z Brake pad replacement question??
I've never replaced the vettes pads before, but when I opened the box there were four thin plates included that had paper attached to one side of the plates. No instructions. I assume that the plates go on the pad on the piston side, between the pad and the piston, and the paper is removed befor installation. But then I thought that maybe the paper is there to reduce "rattle" noise caused by the pad hitting the plate.
What are these plates for and why do they have paper on one side????
:steering:
Old Mar 9, 2004 | 09:27 PM
YELLOWDREAMZ's Avatar
YELLOWDREAMZ
Cruise-In II Veteran
Default Re: PFC-Z Brake pad replacement question?? (TedDBere)
It has been a while since I put those on but I think you peel the paper to reveal a glue. Stick them just like you said in your post. Enjoy.......
Old Mar 9, 2004 | 11:12 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: PFC-Z Brake pad replacement question?? (YELLOWDREAMZ)
That's what you do. Just peel and stick matching the contour. Supposedly they help cut brake squeal, although a lot of pads don't seem to use these any more.
To PFC-Z Brake pad replacement question??
