Plug Wires?
Old Mar 16, 2004 | 04:11 PM
allanlaw's Avatar
allanlaw
Default Re: Plug Wires? (Richin Chicago)
Unless you want to do it for cosmetics or greater heat sheilding the stock plug wires are awfully good. GM says unless the wire exceeds 700 ohms they are good to go. Mine weren't even close to that.
You almost have to have a new set of wires ready to go when you do the first spark plug change on a C5. My experience is that 2 or 3 of the original wires will break during removal. After that, with generous application of grease under the boots, the wires shouldn't break. I went with the red Delco wires 'cause they're pretty cheap and I don't have anything fancy under the hood that would justify going with the fancier wires. :)
