bleeding brakes
Old Mar 11, 2004 | 06:59 AM
wrustywrench's Avatar
wrustywrench
Default bleeding brakes
I am installing new rotors, pads and shocks after the car comes back from DTE with the maggie,,Is there a specific procedure to use to bleed the brakes on a c5,, I will be using the tired and true method of pump and bleed routine. I have a power bleeder if I need it. I will start with the wheel furthest away fomr the master cylinder. Is there any thing I need to do with the anit-lock unit. I really dont want to mess it up, as this is the first car I owned with it. I have heard you need to bleed them also. If I can get buy with out , cool. If not,, what do I need to do. I figure if I use the pump up, bleed , and do it again method, at least I will get most of the old out and not cause a problem with the system. please advise the best, simplest way.. thanks...
Old Mar 11, 2004 | 07:12 AM
Patches's Avatar
Patches
Default Re: bleeding brakes (wrustywrench)
Sent you the preocedure via email.
Old Mar 11, 2004 | 11:07 AM
Jeff Jeff's Avatar
Jeff Jeff
Default Re: bleeding brakes (Patches)
If you have a 2001 and up, the bleed sequence is RR, LF, LR, RF. 2000 and below the sequence is RR, LR, RF, LF.
Old Mar 11, 2004 | 03:35 PM
TedDBere's Avatar
TedDBere
This link should help...
http://www.peachstateposse.com/forum...opic.php?t=532
Good luck.
:steering:
Old Mar 11, 2004 | 03:46 PM
SFVetteman's Avatar
SFVetteman
You can not bleed/flush the ABS unit without a Tech2. You do not need to do anything to the ABS unit just like you do not need to flush the rest of the brake system. The funky old brake fluid will over time cause corrosion of the brake parts but they can be replaced.
Old Mar 11, 2004 | 06:14 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You are such a nice person Patches, you are my hero... would you send me some procedures?Anything.... I need to feel loved... :blueangel: :) :reddevil
Old Mar 11, 2004 | 07:14 PM
Patches's Avatar
Patches
Default Re: bleeding brakes (Evil-Twin)
:lol: :rofl: :lolg: Damn, Bill. Are you sure you're not the Sweet-Twin? :D
How 'bout I send you a torque spec sheet? :)
Old Mar 11, 2004 | 07:21 PM
Evil-Twin's Avatar
Evil-Twin
I want pictures of the puppy
Old Mar 11, 2004 | 07:40 PM
Patches's Avatar
Patches
This little stinker? She's still under 2 lbs. despite my best efforts to spoil her.
Old Mar 11, 2004 | 07:56 PM
Evil-Twin's Avatar
Evil-Twin
They say dogs look alot like their owner... here's living proof...
To bleeding brakes
