sluggish acelaration
Old Mar 11, 2004 | 05:20 PM
Bob50th's Avatar
Bob50th
Default sluggish acelaration
I have a 2003 vert anniversaryedition and since it was new I was never able to spin the wheels from a slow roll.
All is stock. MN6 new GY run flats. only 3,000 miles on it. I took it out to try it again today (50 degrees and dry pavement) and noticed there was a bit of hesitation when I nailed the throttle. Any help would be appreciated.
If I raise the rpm a little it will spin the tires but never from a slow very slow roll?
Thanks :confused:
Old Mar 11, 2004 | 07:35 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: sluggish acelaration (Bob50th)
Take your car to a dyno and run it, then post the sheet here... we will have a good Idea how your car runs if you do that..
VR :cheers:
Old Mar 11, 2004 | 07:42 PM
411_monkey's Avatar
411_monkey
Are you taking off the traction control?
Old Mar 11, 2004 | 08:18 PM
Bob50th's Avatar
Bob50th
Default Re: sluggish acelaration (411_monkey)
yes the traction control is off and i also tried it in performance driving mode. no difference.
thanks
Old Mar 11, 2004 | 11:41 PM
BigBlue's Avatar
BigBlue
My dad's from a slow roll isn't able to break the tires loose either (don't know about after his mod's). You can tell it wants to though. You can just feel the rear tires trying to keep traction. Stock BALD goodyears.
Old Mar 11, 2004 | 11:53 PM
blackjack's Avatar
blackjack
If you turn your steering wheel about a turn to the left from a dead stall and give it abou 3/4 instant throttle the car will respond by spinning the tires and the rear will swing slightly to the right. Immediatly straighten out the car by staightening out the wheel and you should be able to steer it through a nice burnout. I've found this is easier on the car than power braking. Make sure that you have enough road clearance and you feel confident to attempt this.
Best,
BJ
Old Mar 11, 2004 | 11:59 PM
blackjack's Avatar
blackjack
Default Re: sluggish acelaration (blackjack)
OOOps. I misread. You have a MN6. From a slow roll I'd just push in the clutch raise the rpm about 1000, pop the clutch and floor it .
To sluggish acelaration
