Torque Converter Vibration
Old Mar 13, 2004 | 05:03 PM
tahoeC6's Avatar
tahoeC6
Default Torque Converter Vibration
I just installed a new set of 3.42's and a Precision Industries Torque Converter with a 2700 stall. I am experiancing a vibration between 3200 and 4200 RPM's when accelerating/decelerating hard or revving the engine hard in neutral in the same RPM range. I can both feel and hear the vibration, yet when I'm cruising it's gone! (The shop thinks it's the vanes in the converter and said I shouldn't be concerned, however, I dont' have a clue how a converter works much less what's inside one!) The car performs great and I'm really happy with the change. Has anyone else experianced this situation and is it something I should worry about?
:confused:
Old Mar 13, 2004 | 06:02 PM
redvett01's Avatar
redvett01
Default Re: Torque Converter Vibration (tahoeC5)
Have them try indexing the converter. In simple terms remove the three bolts and rotate it 1/3 and bolt it up and test drive it until its OK. :flag
Old Mar 13, 2004 | 06:04 PM
Wt99C5's Avatar
Wt99C5
I (The shop thinks it's the vanes in the converter and said I shouldn't be concerned, however, I dont' have a clue how a converter works much less what's inside one!)
Sorry redvett01, I should have refreshed before posting.
[Modified by Wt99C5, 6:06 PM 3/13/2004]
Old Mar 13, 2004 | 07:45 PM
tahoeC6's Avatar
tahoeC6
Default Re: Torque Converter Vibration (redvett01)
That sounds like a reasonable approach. Can that be done without removing the trans? Seems like I recall that there is an inspection cover that allows access to the converter bolts.
Thanks! :)
Old Mar 13, 2004 | 09:15 PM
SFVetteman's Avatar
SFVetteman
I would phone up Precision Industries and see what they have to say. To me it sounds like the converter is way out of balance and that can not be good :(
[Modified by SFVetteman, 6:16 PM 3/13/2004]
Old Mar 13, 2004 | 09:26 PM
blu00rdstr's Avatar
blu00rdstr
I have the same problem with a Precision Industries Vigilante 3000. But the vibration is there no matter what throttle amount or gear or speed. It's only related to rpm and comes from the back.
Indexing does not seem a good idea, since the torque converter and driveshaft should be balanced independently of each other. Maybe that would make sense if the factory converter and driveshaft were balanced together.
[Modified by blu00rdstr, 6:28 PM 3/13/2004]
Old Mar 13, 2004 | 11:25 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Torque Converter Vibration (blu00rdstr)
:skep: :skep: :confused: :smash:
Old Mar 14, 2004 | 12:35 AM
MikeyD's Avatar
MikeyD
:iagree:
This is one of the suggested fixes straight out of the service manual for vibration in the drive train.
Old Mar 14, 2004 | 01:18 AM
blu00rdstr's Avatar
blu00rdstr
Default Re: Torque Converter Vibration (MikeyD)
I'm still skeptical... :skep:
Old Mar 14, 2004 | 04:19 PM
tahoeC6's Avatar
tahoeC6
Default Re: Torque Converter Vibration (SFVetteman)
I did email them and intend on following up with a telephone call.
Old Mar 14, 2004 | 04:21 PM
tahoeC6's Avatar
tahoeC6
How many miles have you tolerated the vibration? Have you driven the caar hard at all i.e. drags, road course?
Old Mar 14, 2004 | 06:14 PM
blu00rdstr's Avatar
blu00rdstr
It's a mild vibration and not heavy, just enough to notice when passing through a certain rpm range. I installed the converter 6 weeks ago with the FLP trans. I thought it was associated with getting used to a high stall and not getting the fluid level right, or the trans rubbing against something. I've only driven it really hard on an EASE run, but all driving has been on the street with street tires.
Old Mar 15, 2004 | 05:03 PM
tahoeC6's Avatar
tahoeC6
Just got off the phone with Precision Industries, looks like I'll have to send the converter back. They are standing by their warranty and want to make it right. The downside is that my ride will be down for 10+ days with shipping, evaluation, reinstall, etc.... I'll give you a post when it's all done. :(
Old Mar 15, 2004 | 06:51 PM
powderski13's Avatar
powderski13
Glad to hear that PI will make it right. I have a PI 2800 stall with a FLP level IV and Z06 3.42 gears. No problems :flag
To Torque Converter Vibration
