info on a 427!
Old Mar 14, 2004 | 04:47 PM
jimmagrdII's Avatar
jimmagrdII
Default info on a 427!
I have a 2001 coupe, if I wanted to upgrade the engine to a 427 is any parts from the stock ls1 compatable with the 427block ( other than the power steering , etc.) is it woth it . looking for more power but maintain reliability? please any info will help. thanks!! :cheers:
Old Mar 14, 2004 | 05:43 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Default Re: info on a 427! (jimmagrdII)
I'm guessing the only thing that can be reused is the ignition system and the intake manifold (if an LS6)... I suppose you could reuse the stock exhaust manifolds, but.... :leaving:
Old Mar 14, 2004 | 05:55 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Boy to be able to start over again. I would look at this for starters. Good Luck :cheers:
http://www.ls1speed.com/engine1.cfm
Old Mar 14, 2004 | 06:22 PM
Pumba's Avatar
Pumba
Default Re: info on a 427! (Z06GMAN)
Gary,
I would be worried about whoever put that add together.
The stock LS1-LS6 engine uses rods with a center to center distance of 6.104".
The stroke of the advertised 427 is 4.000".
Therefore, the center to center distance of the new rods should be 0.378" shorter than the standard rod - 5.726".
Instead, they advertise a rod with a center to center distance of 6.125". Thats a difference of 0.399" . With that rod length, either the pin is moved up so high that you won't have room for rings, or the piston will extend about the block's deck.
:nono: :confused:
[Modified by Pumba, 6:25 PM 3/14/2004]
Old Mar 14, 2004 | 06:32 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Default Re: info on a 427! (Pumba)
Well heck I don't know............They are a Vendor here. Type O I hope :confused:
Old Mar 14, 2004 | 06:49 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Similar to LPE's Darton sleeve 427 package. That is my dream for next year. No FI, just more cubes, HP, and Torque :smash:
Old Mar 14, 2004 | 06:55 PM
SFVetteman's Avatar
SFVetteman
By 427 block, I take it to mean the C5R block which is about $6400 for the bare block. This is overkill unless you are going to put a Supercharger on it. For N/A applications, you could use the LS1/LS6 Darton block resleeved to a 4.125 bore. At a minimum, you would also need 4.125 bore pistons, 6.125 length rods and a 4.000 stroke crank, and bigger injectors. Everything else on your 2001 can be pressed into service, if need be. It boils down to how much you want to spend and what you want to end up with.
By the way, longer rods are preferred over shorter ones because it reduces the maximum angle of the rod to the crank among other things, which makes for more clearance. There are plenty of off the shelf pistons that will work for the longer rod.
Old Mar 14, 2004 | 08:25 PM
HIGHRPM's Avatar
HIGHRPM
The only thing left in my car from the original LS1 setup is the alternator and power steering pump.. A 427 is a complete upgrade from the 346 LS1 motor.....just trade your motor in as a core and go from there. The heads from your stock motor will not work.....they are chambered for a 3.898" bore, not a 4.125". You need Stage III heads that unshroud the valves and match the 4.125" bore. :cheers:
[Modified by HIGHRPM, 5:28 PM 3/14/2004]
Old Mar 14, 2004 | 10:27 PM
SFVetteman's Avatar
SFVetteman
Default Re: info on a 427! (HIGHRPM)
The fact that stock LS1 heads were designed for a 346 does not mean they will not work on a 427. It does mean they will not work very well and that is true of most of the stock LS1 parts from throttle body to exhaust manifolds and everything in between. That is why I stated that the rest of the stock parts could be pressed into service, if need be. Frankly, I would not want to put money into building a 427 shortblock without stage 3 heads, a more aggressive cam and headers at the very least, but to each his own :cheers:
Old Mar 15, 2004 | 02:07 AM
'97 C5's Avatar
'97 C5
Gary,
:nono: :confused:
6.125" rod length is correct...look at my 427 build pics and you'll see the same combination.
Old Mar 15, 2004 | 08:28 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: info on a 427! ('97 C5)
6.125" is the correct rod length for a 4.00" stroke LS1. The longer rod is required to reduce the rod angle and thus lessen the side-load on the cylinder wall. The wrist pin is moved up higher in the piston for longer rods. My 436ci with a 4.125" stroke uses 6.2" rods.
Basically all your current engine parts will be used except for internal stuff such as rods, crank, pistons, etc. Your head castings would most likely be used, but with all new valvetrain components. A 427 looks no different than your stock motor really other than maybe the little bit of your long tube headers you would be able to see instead of the stock exhaust manifolds. Your stock ignition system is fine, except for probably the spark plugs. Your stock fuel system will work fine, but you will need larger fuel injectors.
If you have any questions or are interested in any information on any of the 427ci LS1 engines Agostino Racing Engines (ARE) has to offer, feel free to drop me an email.
[Modified by MattG, 3:35 PM 3/15/2004]
Old Mar 15, 2004 | 01:28 PM
Sportsdude's Avatar
Sportsdude
773rwhp/675rwtq :eek: :thumbs: :thumbs:
To info on a 427!
