Hit a pot hole
Old Mar 15, 2004 | 05:07 PM
mattbradders's Avatar
mattbradders
Default Hit a pot hole
I hit a pot hole in NYC (and got a $115 parking ticket) and now I have a large lump on the front left tire wall. The tires are original and have 8k miles on them. Can I just replace the one or should I replace the other side too? Thems real expensive!!!
:cheers:
Old Mar 15, 2004 | 05:36 PM
lostsoulny's Avatar
lostsoulny
Default Re: Hit a pot hole (mattbradders)
that why you shouldn't drive the vette in the city, Always amazes me when I see ferrari 360's or the like parked in a garage in the city I say why why why abuse it on these roades. To answer your question if the wear isn't too bad just replace one. I would just replace the one I doubt your fronts wore that quickly. just compare tred depth of existing to a new tire. :seeya
P.S. Far Hills is a beautiful area
[Modified by lostsoulny, 5:36 PM 3/15/2004]
Old Mar 15, 2004 | 06:45 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ________________________
I hope you didn't bend the rim. I hit a pot hole on I-40 about a month ago, It put a bubble in the front tire. I bought a new tire and when they balanced it we discovered the rim was bent. I went home and took the rear tire and rim off and that also was bent. After all was said and done......$850.00 :nonod:
Old Mar 15, 2004 | 06:51 PM
msuc5vette's Avatar
msuc5vette
Default Re: Hit a pot hole (vette#one)
Check the for sale section and try to buy a low mileage used one.
If it is a run flat you should be able to get a good deal, as many people are changing them for other tires.
Old Mar 16, 2004 | 10:18 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Is it still covered by warranty, and if so, does the warranty cover the damage to the tire from potholes (roadhazard coverage)?
Old Mar 16, 2004 | 11:09 AM
Jackal's Avatar
Jackal
If you replace one tire, you should replace the other one also. JMHO
To Hit a pot hole
