Check Engine Light
Old Mar 16, 2004 | 08:21 PM
ltoneal's Avatar
ltoneal
Default Check Engine Light
I have a stock 2000, 6 speed coupe with 42k and the check engine light stays on and doesn't flash. The car seems to run fine. What should I do? The manual says change your gas and take it in if it stays on. Any ideas?
Old Mar 16, 2004 | 08:28 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: Check Engine Light (ltoneal)
Check for codes! Something is up.
turn on ignition, but dont start
press and hold options
while holding options press fuel button 4 times
Then DIC codes will scroll through....write down any codes and post here!
[Modified by sweetcharity, 5:31 PM 3/16/2004]
Old Mar 16, 2004 | 08:31 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: Check Engine Light (sweetcharity)
:iagree:
Old Mar 16, 2004 | 08:34 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The check engine light comes on anytime an emissions-related trouble code is thrown. It could be something very minor, like a loose gas cap, or more serious. Finding out what's wrong is the first step.
Follow these instructions on how to access the codes, and report back with all the codes listed, particularily the PCM code(s). We can at least help you identify the problem area.
Once you jot them down, you can then reset the code(s), this will turn the check engine light out.
https://www.corvetteforum.com/techti...D=26&TopicID=1
:cheers:
Old Mar 16, 2004 | 10:02 PM
ltoneal's Avatar
ltoneal
Default Re: Check Engine Light (Y2Kvert4me)
For the PCM I have p 0410 H C- Air system- B. All the rest of my codes are not "current" except for BCM- B2647. I'll reset my codes in the morning and see what happens. Any other thoughts? :smash:
Old Mar 16, 2004 | 10:32 PM
Bigben's Avatar
Bigben
Had the exact same thing come up yesterday. Hadn't had a chance to look in the manual yet, but I tried what you suggested and came up with the following codes: BO RFA C2105H & 10 PCM P0174H.
Anyone know what these mean??
:rolleyes: :confused: :confused:
Old Mar 16, 2004 | 11:17 PM
MUKAK's Avatar
MUKAK
Default Re: Check Engine Light (Bigben)
:lolg: :lolg:
SELLLL
URRRR
CARRR
:lolg: :lolg: :lolg: :lolg: :lolg:
Old Mar 16, 2004 | 11:55 PM
alc2001's Avatar
alc2001
P0410 is an air pump function check failure. I can send you the manual pages if you like.
Alan :seeya
Old Mar 17, 2004 | 03:40 PM
Bigben's Avatar
Bigben
Default Re: Check Engine Light (alc2001)
ttt
Old Mar 17, 2004 | 06:00 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Had the exact same thing come up yesterday. Hadn't had a chance to look in the manual yet, but I tried what you suggested and came up with the following codes: BO RFA C2105H & 10 PCM P0174H.:
The RFA code is nothing (RFA stands for remote function accessory) this could be your tire pressure monitor system or your key Fob and since it's a history then don't worry.
The other code has to do with the Long term fuel trim and since it's also a history code I say erase them both and drive the car to see if they come back.
Old Mar 17, 2004 | 08:58 PM
ltoneal's Avatar
ltoneal
I reset and got the P 0410 again. It came up about 40 miles later. Send me the manual pages. Any other thoughts?
:smash:
Old Mar 17, 2004 | 09:33 PM
Bigben's Avatar
Bigben
Default Re: Check Engine Light (runamuk)
Thanks for the Tip. Have a warrantee so I think I am going to take it in now for a check up before I install the blower I just bought. :cheers:
To Check Engine Light
