Cartek clutch users
Old Mar 17, 2004 | 03:33 AM
kumar75150's Avatar
kumar75150
Default Cartek clutch users
Is there any chatter at all EVER when you are starting up from a stop?
anyone
Old Mar 17, 2004 | 03:55 AM
kumar75150's Avatar
kumar75150
Default Re: Cartek clutch users (kumar75150)
BTW I have a RAM 910 right now that chatters like crazy.
Before I had a RAM 6130 that chattered like crazy. The clutch stuck to the flywheel and RAM would not even warranty it for me. Their customer service sucked.
Old Mar 17, 2004 | 04:37 AM
EHS's Avatar
EHS
anyone
There have been a number of posts over the years about Cartek clutches and chatter -- some weren't pretty I seem to recall.
From what I remember, the chatter was usually solved by taking a second look at the installation.
Old Mar 17, 2004 | 06:14 AM
ITSovr4U's Avatar
ITSovr4U
My clutch had a little chatter in reverse for a month or so. After that it felt great. Not one bit of chatter now. I am a little scared of it exploding though. :eek:
Old Mar 17, 2004 | 06:35 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Exedy....Exedy....Exedy....do it right for the last time ;) :D :cheers:
Old Mar 17, 2004 | 07:25 AM
99blackFRC's Avatar
99blackFRC
Default Re: Cartek clutch users (Mean Green)
:iagree: This is the route I'll be going to very shortly..
Old Mar 17, 2004 | 07:47 AM
SPEED DOG's Avatar
SPEED DOG
anyone
Not on my setup. I agree with another comment: an adjustable master and meticulous installation is required.
Old Mar 17, 2004 | 07:49 AM
see5's Avatar
see5
I had minor chatter initially. We, the clutch and I, have gotten better to the point I would say I have no chatter. If you back up at low rpm the grab is noticable.
My previous Z06 clutch was smoother but did not last very long. Ths Carteck is plenty strong for me, but I am not running huge hp.
[Modified by see5, 6:53 AM 3/17/2004]
Old Mar 17, 2004 | 08:07 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Cartek clutch users (see5)
I never had any luck with my Cartek clutches unfortunately.
I ran the RAM 910 disk for awhile until I think its chatter took out my torque tube. I then sent my disk back to RAM and had them resurface it as a 980 disk, which is the same as the 910 but has organic material on the flywheel side to lessen the chatter. So far it has been working good with barely any chatter. I hope I can get this clutch to last the whole season, unlike all the others I have tried.
If the RAM 980 dies, its EXEDY time!!! :smash:
Old Mar 17, 2004 | 08:24 AM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Cartek clutch users (ITSovr4U)
I've heard of a few of those myself :eek: It's not SFI rated, so watch out.
The Exedy clutch and flywheel are tested to 15000 RPM and is SFI rated. I bet there's not another clutch for the C5 that can say that!!
I don't think there is a better clutch for the C5 than the Exedy right now :thumbs:
Old Mar 17, 2004 | 08:30 AM
C5 CU's Avatar
C5 CU
Spec just replaced (warranty?) a Spec3...the first had lots of noise and chatter and for some reason car bucked at rpms under 1500...after install of new Spec3 it is like a different world, no bucking, no noise no chatter...i think something mechanically wrong with original from day one...but Spec honored warrenty and replaced the full flywheel-plate-clutch package.
Old Mar 17, 2004 | 01:13 PM
Dope's Avatar
Dope
Resident moron
I have a Cartek. It chatters like a ****, and the pedal effort is akin to leg pressing 150lbs.
Dope
Old Mar 17, 2004 | 01:19 PM
kumar75150's Avatar
kumar75150
Default Re: Cartek clutch users (Dope)
I am going to wait for a couple more of you to get the Exedy I think.
Their clutch description says to expect some chatter because its a ceramic race clutch. I want to make sure that at least 5 people have it with zero chatter before spending the money.
Old Mar 17, 2004 | 01:21 PM
blackbelt's Avatar
blackbelt
I have a catek clutch and a chatters but very little. I love the clutch pedal pressure is a little heavier than stock and grabs hard. Seems some people love them and some don't :confused:
Old Mar 17, 2004 | 01:25 PM
kumar75150's Avatar
kumar75150
Default Re: Cartek clutch users (blackbelt)
seems that way with almost all the clutches
Maybe my new 4.10s will help with driveability. :cuss
[Modified by kumar75150, 1:15 PM 3/17/2004]
Old Mar 17, 2004 | 08:42 PM
EuG's Avatar
EuG
I also have Cartek clutch.
What exactly do you refer to as chatter? :confused:
If I understand this correctly, then it will chatter when I take off at too low of RPM.
It probably also has to do with cam I got in there, but basically you gotta slightly gas the car and the releases the clutch. Hard to describe, but you get used to it fast. If you take off “correctly” I think it doesn’t chatter.
Pedal afford is about twice stock, but I really like that. You get used to that in a few days too btw.
When I get into a car with stock clutch it feels like the clutch would fall apart the first time I hammer it :lol:
To Cartek clutch users
