Tire size numbers ?
Old Mar 19, 2004 | 10:35 PM
4DRUSH's Avatar
4DRUSH
Default Tire size numbers ?
295/35/18 The middle number is the height of the tire ?
How much difference is their between 30 & 40 height ?
Would it change your gearing ?
If so, why not have say 4.10 rear gears for the track with lower tires and higher tires for the street for cruising?
Old Mar 20, 2004 | 12:38 AM
EHS's Avatar
EHS
Default Re: Tire size numbers ? (4DRUSH)
Here you go:
http://www.tirerack.com/tires/tiretech/
and
http://www.miata.net/garage/tirecalc.html
All the answers. :smash:
Old Mar 20, 2004 | 01:08 AM
Midwayman's Avatar
Midwayman
The Middle number is the aspect ratio. Its the height of the tire in relation to its width. (so a 205/40/17 would be less tall than a 275/40/17)
No reason you cant run larger or smaller tires. It will effect your gearing, but also effect your speedo accuracy.
Old Mar 20, 2004 | 02:26 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The middle number (aspect ratio) is expressed as a percentage of the tire's width. So, as a tire gets wider, it also gets taller if it's the same aspect ratio.
For example, a 335/30/18 is a taller tire than a 265/35/18 even though the aspect ratio is less. 30% of 335 happens to be more than 35% of 265.
So, there is no exact height dimension difference unless you specify the tire's width as well.
:cheers:
Old Mar 20, 2004 | 09:44 AM
Pumba's Avatar
Pumba
Jay,
The first number is the width of the tread in mm. The second number is the Aspect ratio, which is a percent of the tread width. These should be followed by the speed rating letter - Z - as an example, followed by the type of construction - R - for radial, next will come the rim diameter in inches - 18. These can be followed by another letter - Y - for example, which designates if it has a speed rating greater than Z.
Here is a formula for calculating the diameter of the tire on its rim:
(Width x Aspect Ratio x 2 x 0.03937) + rim diameter = Tire-Wheel Assembly Diameter
For your 296/35ZR18 tire wheel assembly here is the calculation:
(295 x .35 x 2 x 0.03937) + 18 = 26.129 inches
Good luck :seeya
To Tire size numbers ?
