Cutting radiator shroud for blackwing
Leave it alone. :iagree:
There is really no need to open up either the fog light area or the shroud to get more air to the Blackwing -- it'll breathe just fine -- just like you would if you were under the hood with it closed. Claustrophobia yes, suffocation, no.
Now, before the "cool air" crowd weighs, you will get some "cold air rules" benefit when the car is standing still or moving slowly. That is, cooler air, more performance.
But, since presumably your dad will want the performance when he is actually moving, and not standing in the drivway, I wouldn't sweat that either. By the time the car gets up to 25 mph, the air temperature outside and the air temperature at the Blackwing's location will be the same. That's why Chevy puts the filter where they do, before the radiator fans. It's the breeze thing, again, with all the existing openings, including the wheel wells and the bottom of the compartment. Since the filter isn't zip tied to the exhaust manifold, don't worry about the hot air either.
The best part about not cutting more holes, a lot of Corvette guys like to keep the engine clean as well. I bet so would your dad. You should see the engine compartment after a muddy rain with the fog light area and shroud open.
Cheers! :cheers:
From your post, it's not clear whether you cut the shroud or not when adding the "cold air lid." I assume you did. Did you ever run the test without a cut shroud?
There have been numerous other tests, years ago, that showed that the air temperature change was negligible once the car was moving (like about 10 degrees). As I posted earlier, the intake location isn't zip tied to the exhaust manifold, which is probably the hottest location in the engine compartment.
As far as water ingestion is concerned there is certainly some risk. I ran a Halltech for 2 yrs mounted below the shround on the front spoiler - about 6 inches off the ground. Never had any problem in heavy rain including freeway speeds. I believe the problem is most likely when slowly passing through a deep puddle. With the BW mounted above the shroud there is very low chance that enough water could get up that far in my opinion.
Just my opinion - go with what feels comfortable. :seeya
Just so that some of the folks new to the C5 don't get confused.
Every C5 I've ever seen has the stock air box in front of the fans, which are behind the radiator. Is the there a separation? Yes, but clearly ahead of the radiator and the fans.
I'd also like to mention that Jim Hall has found a significant difference between his TRAP with Tunnel Port and the standard Blackwing (10 HP more for the trap).
That said, I do not agree that the temp of the air entering an above-shroud filter will be anywhere near the same as outside temps even on the freeway! If you look in there, the only way for air to enter a top-breather where the filter is on top of the shroud is to pull air out of the engine compartment and up over the radiator cross bar. In that case, the engine is serving as a huge heating core and it is actually quite efficient at heating air, even at the volumes being sucked by the intake! Even on the freeway, most of the hot air is going to be trapped up at the top: around the hood area, only to get sucked into your intake.
Mike
This proves that cutting the shroud DOES make a difference. In fact, all of the highest-performance intake systems extract cold, outside air in one way or another. Even the K&N FIPK system requires that you cut the shroud to create a flap, allowing in cold air, but retaining a barrier for any water intrusion.
Cold air does make a difference, cutting the shroud does not.
You do understand that difference?
And, Jim Hall sells his own system, just as other vendors do. They all claim their system makes more horsepower. Just like Jim used to claim it couldn't ingest water, and even offered "insurance." That claim is now dropped.
Take a vendor's claims with a grain of salt, particularly if he sells the product.
:seeya
Asking about what's the best air intake and exhaust is like asking what's the best religion. :rant:
So, in other words, your testing was inconclusive? Less than a tenth of a second for the really "cold air" from the Vararam?
:seeya
