Erroneous Tire Pressure Reading
Old Mar 21, 2004 | 10:14 PM
jrose7004's Avatar
jrose7004
Default Re: Erroneous Tire Pressure Reading (ROCKnROLL)
How big or powerful of a magnet do you need to do the training? :chevy
Old Mar 22, 2004 | 12:15 AM
monumentdon's Avatar
monumentdon
Default Erroneous Tire Pressure Reading
I have a 2001 and the darn right rear tire reading keeps indicating a 6 pound under inflation on the message panel. I've checked using two different instruments and they indicate there's no differential compared to the other three tires. Bad sending unit on the right rear, perhaps?
Thanks,
Don :confused: :confused: :confused:
Old Mar 22, 2004 | 12:26 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: Erroneous Tire Pressure Reading (monumentdon)
The TPS's on the C5s are very fickle.
It's possible it could be going bad.
But first you need to reprogram it and see if that corrects it.
Click on this link for the procedure: https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Mar 22, 2004 | 01:02 AM
monumentdon
Gosh, thanks. I'll give it a shot right after church this morning.
Don :) :seeya
Old Mar 22, 2004 | 03:37 AM
tekheid's Avatar
tekheid
Default Re: Erroneous Tire Pressure Reading (jrose7004)
Go to Walmart, to the aquarium supply section. Look for a "Magnetic Algae Cleaner" ($4.99). It is a pair of strong magnets; each encased in black plastic with a felt pad on one side. They are stuck together in the package. Just take them out and use them stuck together, and you have a very strong magnet which will do the job. I just did this earlier tonight and it worked great. Took about 5 seconds per wheel :)
To Erroneous Tire Pressure Reading
