HELP DYNATECH SUPERMAX HEADER INSTALL ?
Old Mar 22, 2004 | 09:43 AM
bamcoc5's Avatar
bamcoc5
Default HELP DYNATECH SUPERMAX HEADER INSTALL ?
I am trying to install the driver side header. Directions state a bottom install. I have my car on jack stands in the front and ramps on the rear. I still don't have sufficent room to install the header. Did any of you raise the engine or go in from the top? I had no problems on the passenger side which went in from the top. I know that if I had a lift it would be a piece of cake. Any info or hints would be greatly appreciated..
Old Mar 22, 2004 | 11:17 AM
vettatude's Avatar
vettatude
Default Re: HELP DYNATECH SUPERMAX HEADER INSTALL ? (bamcoc5)
I did it from the top. I couldn't get the car up high enough either. I had to remove the valve cover and coil packs, and disconnect the steering shaft and move it aside.
Old Mar 22, 2004 | 11:26 AM
bamcoc5's Avatar
bamcoc5
Default Re: HELP DYNATECH SUPERMAX HEADER INSTALL ? (vettatude)
Thanks, that was what I was going to move next. It should be smooth sailing now. I really like the quality of these headers. :seeya
Old Mar 22, 2004 | 11:51 AM
frodo84's Avatar
frodo84
Uneducated autodidact
I just got into the GP on these, just wanted to see if you had any other comments on the install. I doubt I'll have a problem like yours though...I have a lift available :hurray:
Old Mar 22, 2004 | 09:04 PM
spiderman's Avatar
spiderman
I jacked the front end up high enough, used cinder blocks and some boards, with two 4x4's on the jack. had plenty of room from the bottom. Kept adding boards till I had enough clearnace.
To HELP DYNATECH SUPERMAX HEADER INSTALL ?
