ATF fluid change....VOID WARRANTY??????????????/
Old Mar 23, 2004 | 11:00 PM
dogdoc97's Avatar
dogdoc97
Default ATF fluid change....VOID WARRANTY??????????????/
hey guys, some of you suggested that I change to Redline ATF for my sticky manual....will the dealer do it or do I need an independent shop, and what about warranty??? Thanks, Dogdoc :eek:
Old Mar 23, 2004 | 11:17 PM
gonbad's Avatar
gonbad
Default Re: ATF fluid change....VOID WARRANTY??????????????/ (dogdoc97)
It will not void your warranty. It is Dexron compatible. You should do it yourself it is easy. Otherwise get Jiffy Lube or the like as they will be less expensive than the dealer.
Old Mar 23, 2004 | 11:22 PM
dogdoc97's Avatar
dogdoc97
there used to be controversy as to how much oil the car really held VS. manual, what is the correct number of quartsof ATF? dogdoc :skep:
Old Mar 24, 2004 | 12:44 AM
dogdoc97's Avatar
dogdoc97
will adealer do it if asked or not, also I guess I would have to supply the product? Dogodc
Old Mar 24, 2004 | 05:48 AM
Richin Chicago's Avatar
Richin Chicago
For a manual it usually takes just under 4 quarts.
Old Mar 24, 2004 | 07:00 AM
vettenuts's Avatar
vettenuts
Default Re: ATF fluid change....VOID WARRANTY??????????????/ (Richin Chicago)
I have done mine twice now, and I usually get in about 3.5 quarts so if you buy 4 quarts you will be OK. Manual says 4.1, but you will never get that much out.
Old Mar 24, 2004 | 07:57 AM
AFVETTE's Avatar
AFVETTE
I watch a few tranny fliud changes and about the time you start pumping in the fourth quart it'll start over flowing the fill hole. So that's as much as you can get it. Stop and replace the plug.
Bottom line fill until it start running out of the fill hole. I'm getting ready to change out all my fluids to AMSOIL. So I have made it a point to observe a few changes.
Tom
[Modified by AFVETTE, 6:58 AM 3/24/2004]
Old Mar 24, 2004 | 08:04 AM
gmblack3's Avatar
gmblack3
Default Re: ATF fluid change....VOID WARRANTY??????????????/ (AFVETTE)
http://www.woosch.com/tranny_diff_fluid_change.htm
Old Mar 24, 2004 | 10:26 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
The dealer put redilne in my tranny so I sure hope it doesn't void the warranty. :confused:
Old Mar 24, 2004 | 11:19 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
..........I'm getting ready to change out all my fluids to AMSOIL. So I have made it a point to observe a few changes.
Tom
I'm with ya Tom. I changed the differential fluid a month ago to Amsoil, and I just ordered Amsoil ATF. Going to be Amsoil all around pretty soon!!
:cheers:
Old Mar 24, 2004 | 11:47 PM
dogdoc97's Avatar
dogdoc97
guys, forgot to ask, what is the specific number or name of the Amsoil or redline, is it just ATF or does it have a number that matches for the Vette? Dogdoc :confused:
Old Mar 25, 2004 | 12:57 AM
Richin Chicago
For Redline it is D4 ATF
http://www.myoilshop.com/ATF.html
Old Mar 25, 2004 | 09:33 AM
dogdoc97's Avatar
dogdoc97
anybody know if there is a distributor locally in Atlanta for the Redline or AMSOIL; and if so what is product number for AMSOIL; thanks for the Redline number, dogdoc :chevy
Old Mar 25, 2004 | 12:18 PM
gmblack3's Avatar
gmblack3
Tom "IMQUIK" sells amsoil here in Atlanta. His email address is tshac@hotmail.com :cheers:
Old Apr 3, 2004 | 08:55 AM
dogdoc97's Avatar
dogdoc97
hey, I saw where everyone says about 3-4 quarts but does that include the rear diff? I saw a post that said that was two by itself....... Dogdoc :confused:
Old Apr 3, 2004 | 09:13 AM
Richin Chicago
4 quarts of D4 ATF for the six speed and 2 quarts of 75W/90 for the diff. Entirely separate things.
Old Apr 3, 2004 | 09:19 AM
IMQUIK's Avatar
IMQUIK
From the Amsoil site:
Will AMSOIL Motor Oils void the warranty of a new vehicle?
Absolutely not! Manufacturers’ warranties are based upon the use of oils meeting specific API Service Classifications, for example, SJ/CF. (AMSOIL lubricants meet the current API Service requirements and, thus, are perfectly suited for use in any new vehicle without affecting the validity of the new vehicle warranty.)
So Amsoil ATF is Dexron III, and safe to use.
Recommended for applications requiring the following specifications:
GM; Dexron II, Dexron III (GM 6297M, 6417M)
Ford; Mercon, Mercon V
Chrysler; ATF+ through ATF+4
Allison; C-3 & C-4
Caterpillar; TO-2 & TO-3
Voith G1363
ZF; TW-ML-14C
Honda; Z-1
Mitsubishi Diamond SP II & III
GM Strasbourg (European Imports) and Opel
Toyota; Type T and T-IV
Vickers I 286S & M2950S
Old Apr 3, 2004 | 10:16 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: ATF fluid change....VOID WARRANTY??????????????/ (IMQUIK)
If a dealer has to work on your transmission under warranty, how the heck will he really know what kind of fluid is in it? Does Redline and Amsol look any different from Dextron III? I can see the dealer doing minor work on a C5 transmission, such as replacing seals, but I bet they send them out for anthing major that would involve complete disassembly. :confused:
Old Apr 4, 2004 | 01:29 AM
BigBlue's Avatar
BigBlue
Default Re: ATF fluid change....VOID WARRANTY??????????????/ (2kbluestreak)
How often should you change the tranny and diff fluids? Dad's got 17K on his right now and I don't think they've ever been changed. Well, the tranny was probably changed when they replaced the 2nd set of snychros, but that was 10k miles ago.
To ATF fluid change....VOID WARRANTY??????????????/
By Michael S. Palmer | 2026-06-03 09:39:05
