HELP ME!!!!
Old Mar 26, 2004 | 06:41 PM
vetteboy_tr's Avatar
vetteboy_tr
Default HELP ME!!!!
I have several mods in my vette such as Granatelli MAF,Corsa Exhaust.BBK Headers,Vortex Cold Rammer.After I had bought the headers,the engine light appeared next day and the idle went wrong!!!I went to the service and they told me that the stock o2 sensors are out of order and i decided to eliminate the cats and also they added that the headers cannot accept the stock 02 sensors and the cats must be removed.What do you think?My car can't reply for the gas pedals commands!!!How Can I solve the problem?HELP ME PLEASE!!!!
Old Mar 26, 2004 | 06:59 PM
dpd's Avatar
dpd
Default Re: HELP ME!!!! (vetteboy_tr)
o2's out of order and cats need removal?doesn't make sense.what faults do you have?
Old Mar 26, 2004 | 09:03 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Does not compute, O2 sensors out of order. You plug them back in to the same place and do not remove the cats. Removing the cats will cause error codes unless you you sims.
Make sure your headers gasket are not leaking!
Old Mar 26, 2004 | 09:48 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
:confused:
I'm not familiar with the BBK headers but make sure the front O2 sensors are plugged in:
right sensor to right plug and left sensor to left plug
and the rear sensors:
Left sensor to right plug and right sensor to left plug
It's real easy to swap the rear sensors which will throw a code and put the light on, so thats the first place I'd look :cheers:
Old Mar 27, 2004 | 11:28 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: HELP ME!!!! (runamuk)
Runamuk...funny signature..."Yeah, and a magnetic drain plug too" ! :lol:
To HELP ME!!!!
