ZO6 TB/Air Cleaner Flow Test
Old Mar 28, 2004 | 11:03 AM
RedHotZO6's Avatar
RedHotZO6
Default ZO6 TB/Air Cleaner Flow Test
Just flow tested a stock 02 ZO6 Air Cleaner assembly, results are listed below. All test flows are corrected to 10" H2O. The throttle body used was a stock standard LS1 75mm mechanical design. I also flowed my 02 ZO6 body stock and modified. Pics should follow:
Throttle Body LS1 (Stock) = 541.8 CFM
Throttle body w/complete air intake installed (Air bridge to complete air filter with cover) = 397.0 CFM
Removed cover and Air Cleaner = 439.6 CFM
Removed Base (Only Air Bridge and MAF remain) = 448.7 CFM
Removed MAF = 480.0 CFM (Air Bridge Only)
Stock 02 ZO2 Electronic TB = 593.6 CFM (Better than LS1 mechanical TB)
Ported 02 ZO6 Electronic TB = 636.2 CFM
This gives an idea of what modifications in the intake tract will do. There is power to be gained by reducing intake restriction, notice the 145 CFM or so reduction in flow with the air intake assembly bolted up.
Does anyone know how to post pics on this site?
Thanks, Paul
Old Mar 28, 2004 | 11:17 AM
RedHotZO6's Avatar
RedHotZO6
Default Re: ZO6 TB/Air Cleaner Flow Test (RedHotZO6)
For reference, a 347 cubich inch motor turning 6500 RPM with 100% volumetric efficiency (not likely except for full race motor) will pull in about 650 CFM of air. From the flow results, there is not much power to be gained going with a larger than 75mm ported stock TB. At 10" of H2O test pressure, you have only .35 psi of pressure difference.
For a big 427 stroker, there may be some power to be gained going with a 90mm or larger TB.
The moral is, spend your money on other things, just trying to give fellow performance enthusiasts a heads up.
Paul
Old Mar 28, 2004 | 11:30 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Excellent data. Thanks.
Old Mar 28, 2004 | 12:28 PM
cfi_luz's Avatar
cfi_luz
Default Re: ZO6 TB/Air Cleaner Flow Test (99C5Vert)
Wow, awesome date. THere have been several guys asking for this information for a long time. Thanks for helping everyone out :cheers: Now we need someone to test the 90mm TB and maybe some aftermarket intakes. :yesnod:
Old Mar 28, 2004 | 12:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: ZO6 TB/Air Cleaner Flow Test (cfi_luz)
Great data!! :thumbs: Is there any way you could test some of those carbon fiber bridges and smooth couplers to see if they help? That would put alot of claims to rest!
Looks like I will be porting my TB!
Thanks again!
Bill Curlee
Old Mar 28, 2004 | 12:39 PM
RedHotZO6's Avatar
RedHotZO6
If anyone in the Houston area or close would be willing to bring by or ship any other parts, 90mm TB's, Air bridges, etc, I will test them and post it on this thread. It would be a good apples to apples test. Thanks,
Paul
Old Mar 28, 2004 | 01:02 PM
RedHotZO6's Avatar
RedHotZO6
Old Mar 28, 2004 | 01:06 PM
RedHotZO6's Avatar
RedHotZO6
Boring throttle body:
Old Mar 28, 2004 | 01:12 PM
RedHotZO6's Avatar
RedHotZO6
Donor Car:
To ZO6 TB/Air Cleaner Flow Test
