Jacking a C5?
Old Apr 1, 2004 | 03:38 PM
GRAYT VERT's Avatar
GRAYT VERT
From: Not QUITE the armpit of Southern Maryland, but scary close...
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'06
Default Jacking a C5?
Forgive a newbie for asking a question I'm sure has been asked before, but.... Want to paint the calipers on my new C5, but don't have access to a lift. If I'm supposed to use the jacking pads to jack the car up, then where do I place the jackstands to remove the jack and go to the other side? Any help on this would be great!!
Thanks,
Dave
:flag :seeya
Old Apr 1, 2004 | 04:13 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Default Re: Jacking a C5? (GRAYT VERT)
Hope this helps...also try jacking from the crossmember then you can get both stands in at the same time..Good luck
[Modified by sweetcharity, 1:14 PM 4/1/2004]
[Modified by sweetcharity, 1:15 PM 4/1/2004]
[Modified by sweetcharity, 1:16 PM 4/1/2004]
Old Apr 1, 2004 | 05:09 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Get some Rhino Ramps
Remove both wheels at the same time.
[Modified by wallstAL, 2:10 PM 4/1/2004]
Old Apr 1, 2004 | 05:25 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Jacking a C5? (wallstAL)
I have the easiest way.....
Jack the front of the car up until the jack is at it's highest point. Put jackstands with pucks under the front chassis points for lifting. Lower the front to the jackstands and the rear will raise slightly. Move to the rear of the car and jack to highest point. Install Jackstands with pucks. Now the car will be 12-20" depending on jackstand height off of the ground. Reverse to remove.
Phillip
Old Apr 1, 2004 | 05:26 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Jacking a C5? (Phil97SVT)
Jack front from the center of the cross member and rear from the center of the cross member also. Jack stands should go at the front and rear of both doors in the lift positions.
Old Apr 1, 2004 | 05:34 PM
GRAYT VERT's Avatar
GRAYT VERT
OK Everybody,
Thanks for the input. It's just what I was looking for. And, I will be getting some Rhino Ramps this weekend, they look like the are just the ticket for getting under the car when necessary!
Dave
:seeya :flag
To Jacking a C5?
