dead battery and codes
Old Apr 2, 2004 | 09:42 AM
ironarms's Avatar
ironarms
St. Jude Donor '05-'08-'09
Default dead battery and codes
Hello all, I am new here and was hoping someone could help me out, I have an 03 convertible, well since i live in the great north east where it snows all the time the car sat in the garage all winter, well to make a long story short , twas dead, i pulled it out and charged it for a few days , now when i started it i have all kinds of trouble codes such as shocks inoperative,engine at reduced power. the power windows are locked up, i called the dealer they said it was normal and the needed to reprogram the computer? I find this hard to believe everytime i need to disconnect the battery i will have to reprogram the cars ecm, the car only has 200 miles on it, Thank you in advance for your help !!
Old Apr 2, 2004 | 10:15 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: dead battery and codes (awalters)
Make sure you have the battery fully charged (at least 8 hours with a 10 amp charger) and try over if you don't get any more messages erase all the codes.
http://www.stengel.net/diccodes.htm
Old Apr 2, 2004 | 10:24 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: dead battery and codes (Richin Chicago)
:iagree:
Here are a couple of other links to read and erase any codes you have.
Getting DTC's
https://www.corvetteforum.com/techti...D=26&TopicID=1
Erasing DTC's
https://www.corvetteforum.com/techti...D=25&TopicID=1
[Modified by runamuk, 9:24 AM 4/2/2004]
Old Apr 2, 2004 | 11:37 AM
ironarms's Avatar
ironarms
thanks for your help! i had charged the battery for a couple days and ( 6hrs on 30 amps 2 days on 2 amps) had good readings when i installed it so i should just have to errase the codes.... I appreciate the help!
Old Apr 3, 2004 | 11:39 AM
carpe dm's Avatar
carpe dm
Clear the codes and hopefully you will be OK. Sometimes a fully discharged battery will not take a good/complete charge and will have to be replaced. Check it out and if you have any problems, take to your dealer and get a new one. :yesnod: :) BTW, NEVER store your car with the battery still connected. Use a Battery Tender for short down times. :thumbs:
[Modified by carpe dm, 9:41 AM 4/3/2004]
Old Apr 3, 2004 | 12:12 PM
fast4vette's Avatar
fast4vette
i have seen bogus codes pop up with reconnecting a battery.
just clear them and you should be fine.
it's no big deal.
:cheers:
Old Apr 3, 2004 | 12:43 PM
Richin Chicago
Default Re: dead battery and codes (fast4vette)
it's no big deal.
:cheers:
It's not the disconecting and reconnecting the battery that tends to throw the codes but having the battery swing below about 10 volts, when trying to start the car that get the CPU's undies in a bunch.
Old Apr 3, 2004 | 01:02 PM
ironarms's Avatar
ironarms
I just wanted to thank you all again for all your help! I hope i will be able to return the favor sometime :troll
To dead battery and codes
