Do I need O2 sims or can I delete rear sensor codes?
Old Apr 2, 2004 | 10:28 AM
Bone_Stock's Avatar
Bone_Stock
Default Do I need O2 sims or can I delete rear sensor codes?
Does deleting the rear O2 sensors cause any loss in performance or give your pcm false readings. I have the LG long tubes with off-road X-pipe. Let me know what you guys suggest.
Old Apr 2, 2004 | 10:38 AM
FRC sexi blk's Avatar
FRC sexi blk
Default Re: Do I need O2 sims or can I delete rear sensor codes? (Bone_Stock)
kiss the sims. they add .89 LBS! :cry
you can remove the codes easily with LS1 edit, no need to even buy it. go to a tuner and for $20-30 or what ever you buy him he can do it. So easy to do.
presto :seeya
Old Apr 2, 2004 | 10:53 AM
Blow Torch's Avatar
Blow Torch
Default Re: Do I need O2 sims or can I delete rear sensor codes? (FRC sexi blk)
:iagree:
Old Apr 2, 2004 | 11:45 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
You may have to have the rear sensors deleted or run SIMS, With no CATS and before Predator deleted them I would throw codes all the time - And no there is no power loss with either
[Modified by Ragtop_Rob, 10:48 AM 4/2/2004]
Old Apr 3, 2004 | 11:17 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Default Re: Do I need O2 sims or can I delete rear sensor codes? (Ragtop_Rob)
I hate to post this but :
Im running the stock senors with my kooks LT header and high flo cats welded to the X-pipe. I have 300 hard fun miles since they where installs, and havent thrown a code..................... yet
Hope posting this doesnt give me bad luck
The tech that installed them said run the stocks to see if they work before buying something else :shocked:
Old Apr 4, 2004 | 06:19 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Default Re: Do I need O2 sims or can I delete rear sensor codes? (phils C5 vette)
:iagree: I was told the same thing - but I got greedy and took the High Flow CATS off -Try it and see what you get! :reddevil
Old Apr 4, 2004 | 11:29 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
I damaged one of my rear O2 sims when I was driving to the exhaust shop after i installed my headers so I just left them off and had them deleted when I got the car tuned. It did throw codes before getting it tuned. I was throwing lean codes. Kaley
To Do I need O2 sims or can I delete rear sensor codes?
