Wheel senors
Old Apr 4, 2004 | 12:04 PM
2001convertable's Avatar
2001convertable
Default Wheel senors
I just changed my wheels to chrome zo6. After having them mounted I disconnected the battery to reset the sensors in the wheels. All the wheels are reading great except for the front right. The right side front is not reading at all. Maybe someone can help me with this. Thanks
Old Apr 4, 2004 | 11:55 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: Wheel senors (2001convertable)
It really wasn't necessary to disconnect the battery because it does not have anything to do with the sensors. As long as you put the sensors back on the same corners they came from they should be fine. But of course there is always one that doesn't want to co-operate and all it probably needs is to be reprogrammed. Here is the procedure. Click here: https://www.corvetteforum.com/techti...D=77&TopicID=1
