Driver's seat problem
Old Apr 4, 2004 | 04:28 PM
Crazy Cowboy's Avatar
Crazy Cowboy
Premium Supporting Vendor
From: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Driver's seat problem
I'm setting a DIC code in LDCM code for battery 2 failure. My driver's seat is not operating at all! Anyone know what battery it's talking about!?!
Old Apr 5, 2004 | 12:22 PM
carpe dm's Avatar
carpe dm
Default Re: Driver's seat problem (Crazy C5 Cowboy)
:confused: :lurk: Can you give us the exact code? Check the electrical connector beneath the seat, fuse, and the connector in the rubber "accordian" between the driver's door and the body.
Old Apr 5, 2004 | 05:57 PM
Crazy Cowboy
Cruise-In V Veteran
Default Re: Driver's seat problem (carpe dm)
Sure, the code is LDCM 2284. My driver's seat stopped working while I was adjusting it and now nothing works including the lumbar. I swapped the seats and put the passenger on the driver's side to see if the power from the car was there and the seat worked fine. So that ruled out the plug's power from the car being bad. Swapped the passenger seat power control panel onto the driver's and the seat still didn't work at all. All the wires and plugs appear to be clean and undamaged. All plugs checked to make sure they were ok. Only thing I can think of is that it has to be the SCM box under the seat there. The passenger side is different or I would have tried it too. Let me know what you think!
:cheers: - Dan
To Driver's seat problem
