5.3 heads
Old Apr 4, 2004 | 08:06 PM
lar66BB's Avatar
lar66BB
Default 5.3 heads
What are the pros and cons of using the truck 5.3 heads on a LS1.
:cheers:
Old Apr 4, 2004 | 11:16 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: 5.3 heads (lar66BB)
I have TEA 5.3 liter heads on my car. I haven't had any other head so I am not sure if they are better or worse. They do raise the compression. I was told that by milling them .10 it will bump your compression to around 11:1. I am sure someone will chime in with better info then me. Kaley
Old Apr 5, 2004 | 09:12 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: 5.3 heads (2C5only21)
Running TEAs too. The 5.3s have a smaller chamber that boost compression without milling that will cost you piston to valve clearance.
Old Apr 5, 2004 | 09:26 AM
6Speeder's Avatar
6Speeder
Default Re: 5.3 heads (93Polo)
My 5.3's were built up by Morgan Motorsports and are milled to gve 11.4:1 compression. They work great, see sig for results with small cam. :cheers:
To 5.3 heads
