C5 clutch chater
Old Apr 5, 2004 | 03:55 PM
gphair's Avatar
gphair
Cruising
Default C5 clutch chater
I have my first C5 6 speed and experience some clutch chatter noise when starting from a dead stop in 1st gear. I'm told that's normal. What is it and is there a fix?
Old Apr 5, 2004 | 05:00 PM
breabob's Avatar
breabob
Default Re: C5 clutch chater (gphair)
You can get chatter. Depends on the mileage. If it has low mileage and chattering, there could be a problem. If you bought it used, it could have been from the previous owner's driving habits. Chatter usually is a result from some spots on the flywheel. On most flywheels you pull the flywheel and resurface it. On the Vette you buy a new one, it comes as an assembly. I would have the rpms up a little more when you take off and you might find it smooths out. The clutch lasts a long time. A little chatter is not a concern.
Old Apr 5, 2004 | 05:15 PM
Fulano's Avatar
Fulano
Good to know!
I have the same issue with my 98 Vert, which only has 20K miles on it...but at higher rpm takeoffs I do not notice the "rattle" or "chatter".
Guess I'll go for a heavyduty cluth when I save up for my supercharger and get rid of the issue :cheers:
To C5 clutch chater
