Brake Pad Replacement - Turn Rotors???
Old Apr 5, 2004 | 07:35 PM
99 MagRedVette's Avatar
99 MagRedVette
Default Brake Pad Replacement - Turn Rotors???
Just got a new set of brake pads today and I was wondering if, when I replace the pads should I have the rotors turned? The rotors were replaced about 20k miles ago and look good with no gouges or scoring. What's the right way to do this??? :confused:
Also, anyone know of a good site with a description of the process? Any tips or things I should look out for? 1st time I've done this on a C5...
Old Apr 5, 2004 | 08:02 PM
Kenny94945's Avatar
Kenny94945
Default Re: Brake Pad Replacement - Turn Rotors??? (99 MagRedVette)
iF not warped I'd reuse them.
Turning makes them thinner and therefore earier to warp.
Else, replace them...what's the cost OEM @ $70 a peice?
Old Apr 5, 2004 | 09:19 PM
gmblack3's Avatar
gmblack3
Default Re: Brake Pad Replacement - Turn Rotors??? (Kenny94945)
http://www.z06vette.com/forums/showt...ighlight=brake
Your rotors should be fine.
rockauto.com sells the raybestos rotors for $100 shipped set of 4.
To Brake Pad Replacement - Turn Rotors???
