*** Need Help With Error Message***
Old Apr 5, 2004 | 09:22 PM
jjk2509's Avatar
jjk2509
Default *** Need Help With Error Message***
The message center tells me to service vehicle soon. I checked the computer codes and I get the following code: 28-TCS-C1281H (Steering Sensor Uncorrelated Malfunction). I cleared the code the code message came back.
Does anyone know what would cause this message? I recently removed the instrument gauges.
Thanks for any help.
:flag :flag
Old Apr 6, 2004 | 05:12 AM
jjk2509's Avatar
jjk2509
Default Re: *** Need Help With Error Message*** (jjk2509)
ttt
Old Apr 6, 2004 | 09:32 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Commonly caused by a faulty steering position sensor,requires removing the steering column to replace :yesnod:
Old Apr 6, 2004 | 11:33 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: *** Need Help With Error Message*** (C-5 TECH)
That sensor is in the column, I was under the impression it was in the rack??
Old Apr 6, 2004 | 10:14 PM
jjk2509's Avatar
jjk2509
What is the sensor used for? Is there a problem with driving the car the way it is?
Thanks for the help.
Old Apr 7, 2004 | 10:47 PM
BHP's Avatar
BHP
Default Re: *** Need Help With Error Message*** (runamuk)
Looks like a doughnut at the bottom the column. Semi-PITA to fix.
Old Apr 8, 2004 | 12:58 PM
mapman's Avatar
mapman
C1241 indicates an open, short to ground, or short to voltage in the Variable Effort Steering (VES) actuator or the circuits to the actuator.
VES uses the Electronic Brake Control Module (EBCM) to control current to an electronic actuator. At low speeds this actuator assists the hydraulic power steering to make steering easier, at moderate speeds the actuator does not assist steering (hydraulics only), and at high speeds the actuator creases additional steering resistance.
When C1241 is set the VES system is disabled, that is you only have your hydraulic power steering working. The diagnostic tests use a scan tool to monitor the VES at various vehicle speeds in order to isolate the problem.
To *** Need Help With Error Message***
