Why Is Alignment Needed When Lowering?
Old Apr 6, 2004 | 12:20 PM
BluGem's Avatar
BluGem
Default Why Is Alignment Needed When Lowering?
I am considering lowering my 02 Vert, about an inch, for appearance more than anything. Can people chime in why lowering the car an inch changes the alignment characteristics of the vehicle and suspension? Will I also notice any handling improvements with an inch of lowering? I have the Z-51 suspension and will be putting on the Z06 front anti-sway bar. Thanks in advance for your responses.
Marc in Bend, Oregon
2002 EB Vert 6-sp
Old Apr 6, 2004 | 12:36 PM
T_Vert's Avatar
T_Vert
Default Re: Why Is Alignment Needed When Lowering? (BluGem)
well as you lower your car you create negative camber (tops of tires point in) because the camber links are stationary and you are moving their pivot point . Think of it like this. As you load the suspension as in a corner etc, you create negative camber. If you ever were into rc cars you could easily replicate what im talking about.
Dave
Old Apr 6, 2004 | 12:58 PM
BHP's Avatar
BHP
It will increase negative camber but may still be in an acceptable range. Tires also make a difference. You can run a little more negative camber with non-run flats. Handling will improve and suspension travel is still OK with Z51.
Old Apr 6, 2004 | 01:02 PM
APT's Avatar
APT
You might "feel" a slight improvement, but real, measurable improvements are insignificant. As for alignment, keep in mind that even the factory settings might be off, which will be exagerrated after lowering. Always a good idea to get a periodic alignment even if your car is bone stock.
Lowering by itself is really for :cool: factor.
:cheers:
Old Apr 6, 2004 | 01:36 PM
ryan0's Avatar
ryan0
Default Re: Why Is Alignment Needed When Lowering? (BHP)
neg camber good..
more toe in bad...
To Why Is Alignment Needed When Lowering?
