No spark.
Old Apr 11, 2004 | 02:06 AM
rsherrard's Avatar
rsherrard
Default No spark.
I've been in the process of putting a new motor into my car.... and ran into an interesting issue today; maybe one of you can help me out?
Basically, the issue is that I get no spark from my coil packs. There's voltage / power at the coils, yet for some reason no trigger signal is being sent from the PCM. The other interesting thing is that there's no reference voltage going to / at the coils. The service manual suggests that there should be; however there isn't. The injectors are also getting pulsed when trying to start the car, just no spark. We’ve checked ALL wiring, fuses, and relays w/ no luck, everything appears to be within spec, with the exception of the items listed above. At this point, the only we can think of doing is replacing my PCM? Has my PCM gone bad?
In need of some help,
Rob
Old Apr 11, 2004 | 11:12 AM
mapman's Avatar
mapman
Default Re: No spark. (rsherrard)
Any Diagnostic Trouble Codes set?
Old Apr 11, 2004 | 01:22 PM
rsherrard's Avatar
rsherrard
Default Re: No spark. (mapman)
no codes...
Rob
Old Apr 11, 2004 | 02:06 PM
dpd's Avatar
dpd
atre you sure the ground on the left rear head[bank 1]is on or tight.this is the ground for both coil packs.
Old Apr 11, 2004 | 04:19 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Did you do the crankshaft position sensor relearn procedure?
Old Apr 12, 2004 | 02:32 PM
rsherrard's Avatar
rsherrard
Default Re: No spark. (runamuk)
What's the process on how to force a relearn?
Rob
Old Apr 12, 2004 | 02:50 PM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
It would still run..just set a code...Check the ground like he said...driver's side head, in the back
To No spark.
