I bought a 2002 Z a few months ago, which has breathless headers. I found that I have what sounds like several leaks coming from the system. I am hearing that this is a common problem with no solution. The leaks are so bad that at times the cabin fills with fumes and driving up hills causes the leaks to be very loud and irritating.
Is there something I can do to fix this? I am going to replace the header to motor gasket, but also need info for the rest of the system....welding? new gaskets? gasket maker stuff??????
Re: Breathless Power Performance header questions (Z06ufgrad2002)
Do you have the one or two piece headers?
I've seen a set that had the two piece design. It leaked at the tube junction, the owner used that aluminized tape to seal it. :nonod: Just kind of sounds like the same problem
