Racing battery install writeup completed
Old Apr 11, 2004 | 11:54 AM
JakeL's Avatar
JakeL
Default Racing battery install writeup completed
Hey all -
With my Eclipse, I always wrote up how-tos on the projects that I did for the car, similar to how jmX does, but since he's had most of the bases covered for C5's, I haven't spent much time doing that with the Corvette.
Well, I finally did a mod that he doesn't have on his site, so I took a few minutes and did a bit of a writeup of this one.
This is the install of a 13lb Hawker racing battery, and the bracket I made for tying it down.
Hope you enjoy it - and let me know of any things that are unclear, typos, etc etc:
http://www.jakelatham.com/C5/projects/battery/
Cheers!
-Jake
Old Apr 11, 2004 | 11:55 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Racing battery install writeup completed (JakeL)
VERY NICE..... :cheers:
Old Apr 11, 2004 | 12:24 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Thanks! Great idea and super write up! :yesnod: :thumbs:
Old Apr 11, 2004 | 12:27 PM
RWhite's Avatar
RWhite
Pretty :cool: writeup!
Old Apr 11, 2004 | 01:04 PM
BHP's Avatar
BHP
:cool: Did a similar project about two months ago. The Battery saves 25 lbs. in weight. Since it is a drycell type it will not leak. It will hold a charge for a good two weeks. I opted for the metal jacket version that will handle higher engine bay temps.
The bracket I made was a simple design with a threaded rod on each side of the battery. I used a piece of aluminum channel to secure the battery on the top, laying down flat, with nylocks. Covered the rods and channel in HD shrink tube. I used a vinyl pad on the battery tray for shock absorption.
Here are some links for those interested in this type of battery:
http://www.stealth316.com/2-dynabatt.htm
http://www.gotbatteries.com/Productp...ctNum=37L105S7
[Modified by BHP, 10:05 AM 4/11/2004]
Old Apr 11, 2004 | 01:13 PM
JakeL's Avatar
JakeL
Default Re: Racing battery install writeup completed (BHP)
I have read that the later cars had a slightly lighter battery. On mine, it saved 30lbs.
Those are good links - same ones as in my writeup as well. Sure is nice to have that information available.
Do you have any pictures of your work? I'd be curious to see what others ideas were like.
Thanks for the kind words all,
-Jake
To Racing battery install writeup completed
