How much are you planning on lowering it? If you are not lowering to much I wouldn't worry about it. If you plan on cutting bushings and longer bolts I would get it aligned. kaley
I'm probably going to cut the bushings, but not longer bolts.
Last summer I had it lowred as far as stock bolts would allow in the back, it seemed like my inner tread wore a litte more than my outer tread, but I now have 30K miles on the original tires.
I am buying new tires, and just don't want to kill them prematurely.
If I cut the bushings up front am I going to need an alignment do you think?
