Brake Job...
Old Apr 11, 2004 | 07:53 PM
99PewterVette's Avatar
99PewterVette
Default Brake Job...
I getting ready to replace my rotors, w/ Bendix drilled and slotted, the pads w/ Rotex Kevlar pads, remove and paint the calipers and replace the rubber brake lines w/ Goodridge steal braided lines. Any advice to make this job go smoothly... :auto:
Old Apr 12, 2004 | 01:46 PM
stevenll's Avatar
stevenll
Default Re: Brake Job... (99PewterVette)
I have 13 pages of illustrated instructions I can fax you on the rotor & pad replacement. Send me an IM & I'll fax them to you. A couple suggestions. Get a 1/2" breaker bar & a 21mm socket if you don't have it. The bolts that hold the caliper mounting bracket are tough to remove. You'll need a lot of leverage. Also, some Liquid Wrench will be helpful in removing the rear rotors. Overall it's a pretty easy job. You should consider changing the rotors first & seasoning them for a couple weeks with the old pads before installing the new pads. That way the old pads will pick up the zinc from the rotors. You'll also need some red LocTite.
Old Apr 12, 2004 | 02:25 PM
Patches's Avatar
Patches
I sent you the illustrated procedures via email. Hopefully, they went through. Let me know if they didn't as I often have to limit the size of emails to AOL.
:cheers:
To Brake Job...
