I bought a set of C5 base seats with power rails and I need to remove the rails to install them on another set of rails. The bolts are facing up and hard to get to, do I have to remove the seat foam to get to the bolt or is there another way.
You can remove the seat foam, that is the easiest method. But you can slip a box end wrench up under the foam to get onto the bolt head. It is a bit of a pain to do, but I have done it both ways.
