How do you prime fuel injectors?
Old Apr 13, 2004 | 08:21 PM
Smokin Joe's Avatar
Smokin Joe
Default How do you prime fuel injectors?
You know if you were to run them dry...or install new ones.
Why is it necessary?
Old Apr 13, 2004 | 08:52 PM
Old Timer's Avatar
Old Timer
Default Re: How do you prime fuel injectors? (SpyRacing)
I just replaced mine. Just stuck them in and turned on the ignition and let the fuel pump run a couple of seconds. Engine fired right up nice and smooth. :auto:
Old Apr 13, 2004 | 11:54 PM
DngrZne's Avatar
DngrZne
Default Re: How do you prime fuel injectors? (Old Timer)
I imagine if there was that much air you could let the fuel pump pressurize the system, shut it off, then press the pin in on the pressure gauge connector on the end of the fuel rail to bleed the air.
Old Apr 14, 2004 | 09:24 AM
Mr. Jones's Avatar
Mr. Jones
Default Re: How do you prime fuel injectors? (DngrZne)
same here, I replaced mine (30lb), turned on the key, let the fuel pump work a little and started right up.
To How do you prime fuel injectors?
