Help, I Need Ideas!!
Old Apr 16, 2004 | 10:57 PM
jpee's Avatar
jpee
Default Re: Help, I Need Ideas!! (wallstAL)
I never had any idea the M/T would cause me to lose that much in mph and a little in ET's :mad :mad :mad Only compensation is that M/T's hook very consistantly.
The M/T weigh 12 lbs less than the 17X11 drag radials X2=24 lbs.
Thanks for all your help!!!!!!!
Yup I knew the ET's were lighter, but what do you care about ET or MPH if your gonna Bracket Race... if you were running Heads Up.. then I'd agree..
When I had the 3000 converter I'd run low 12's but not consistantly on DRs so I went to a 2600 converter I slowed down to 12.7's but it is very consistant!
Old Apr 17, 2004 | 01:00 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Help, I Need Ideas!! (Red96Coupe)
I like heads up with people in my category and brackets with the WCCC maybe 4 times a year.
Old Apr 17, 2004 | 11:25 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
:cheers:
Good deal Al!
I can bracket the 97' running on a 11.05 right now on the drs all day long with a 1.52-1.55 60's...now if the driver could be consistant on the tree!
Lucky now adays if I go to the track 4 times a year......thats why I like these shoot-outs & CF Cruise Ins........I can get in 25 passes easy each day:yesnod:
Now the quest......get the 97' to a 10.0 NA and the 00' into the 10's NA on the stock block :D
Keep it straight :thumbs:
