shifter knob disaster!
Old Apr 14, 2004 | 09:20 AM
dpd's Avatar
dpd
Default shifter **** disaster!
ok,i went to swap over my shifter ****,when i went to pull the wedge out,it broke.anybody got any ideas on how to get it out.mind you i had this apart a week ago with out any problems.
thanks guys,i did the old drill a hole and sheet metal screw theory and the dam wedge popped right out[not 1 curse word used].you just can't make this up!
[Modified by dpd, 4:07 PM 4/14/2004]
Old Apr 14, 2004 | 09:56 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Re: shifter **** disaster! (dpd)
I would try to drill it out. It just slides into a groove in the shifter and gets wedged in there. Use a small bit to start and enlarge it slowly to avoid damaging the shaft.
Old Apr 14, 2004 | 10:17 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
That sucks! Are you getting rid of the **** that is on there now? If WORSE comes to WORSE, you could cut off the old **** to get access to the slot on the back side of the shifter shaft (say that fast five times) then get the darn key out
Old Apr 14, 2004 | 10:19 AM
TXSTICK's Avatar
TXSTICK
If you really need it off, you could use a hack saw and slowly cut down the side of the ****. I would cut down both sides and then you can tap out the pin. Go slow and dont mess up the threads on the shaft. I would not cut all of the way to the shaft, just far enough to get a flat blade in the side and split it open.
Old Apr 14, 2004 | 10:22 AM
TXSTICK's Avatar
TXSTICK
Default Re: shifter **** disaster! (TXSTICK)
Ragtop, we must have been typing at the same time. :)
To shifter knob disaster!
