TRANNY FLUID
Old Apr 15, 2004 | 11:08 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Default TRANNY FLUID
I recently added a transmission cooler to my C5 (NEW OWNER) and when I went to check the tranny fluid level I found that it is like an F-BODY...There is no dipstick. How do you add tranny fluid without having to go to the dealership?
Yeah, yeah, I know I am stuuuuuuuupid!
Old Apr 15, 2004 | 12:39 PM
ersatz928's Avatar
ersatz928
Default Re: TRANNY FLUID (mph1972)
I believe there is a dipstick on the tranny, access is only from underneath, in the rear.
Old Apr 15, 2004 | 12:46 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
1. raise the car so it's level and you can crawl under the back
2. start the car and get the transmission temp between 86 - 122 degrees F
3. once the temp reaches this level shift into each gear pausing for a second or 2 in each selection from P to 1 and back to P
4. With the engine still running and the transmission in Park remove the plug on the left side of the tranny pan and fill until fluid begins to overflow.
Thats it :cheers:
To TRANNY FLUID
