Rotor install ??? 's
Old Apr 15, 2004 | 09:11 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Rotor install ??? 's
I just got my Baer Eradispeed rotors & Hawk pads, can someone tell me the proper torque of the caliper bolts, and should one use "locktite" Thanks! Greg :cheers: :steering:
Old Apr 15, 2004 | 10:01 PM
bowtiebubba's Avatar
bowtiebubba
Default Re: Rotor install ??? 's (3Vettes@Home)
I just did mine and the caliper bracket bolts were a 125 lbs and the caliper bolts were i think 23lbs and i used the blue loctite on all 4 bolts. the hardest part was breaking the caliper bracket bolts loose and trying to get a torque wrench worked around enough to get the bolts tight again.
Old Apr 15, 2004 | 10:05 PM
3Vettes@Home
Cruise-In V Veteran
Default Re: Rotor install ??? 's (bowtiebubba)
Thanks! I appreciate the help.. :cheers:
To Rotor install ??? 's
