Need help wiring manual fan on/off switch
Old Apr 17, 2004 | 11:41 AM
HP_Addict's Avatar
HP_Addict
Default Need help wiring manual fan on/off switch
Guys,
I want to install a manual toggle switch so that I can turn the elec fans on while sitting in the staging lanes. I did a search and found some conflicting information. I found the schematic and it looks like the easiest way would be to install a SPDT relay inline with the white wire going to the right fan. This should turn this fan on at high speed and not affect PCM operation. Has anyone found a better way to do this? And is there a way to run both fans at high speed? SLP sells a wiring connector for the Camaros, anyone know if there is a similar connector for the Vette?
Thanks for the help
Chris
Old Apr 17, 2004 | 12:30 PM
ken-rx's Avatar
ken-rx
Default Re: Need help wiring manual fan on/off switch (marlowchris)
Look in tech tips to install a fan controller. The member who wrote it did a terrific job.Clear, concise and it explains how to put an overide in also.
Old Apr 19, 2004 | 09:02 AM
HP_Addict's Avatar
HP_Addict
Default Re: Need help wiring manual fan on/off switch (ken-rx)
I have seen that, but I do not need the adjustment and it seems like there would be a easier way to install a on/of switch. Jim (Intel55) said he emailed a bunch of guys a schematic to do this a few years ago. Does anyone still have this? If so could you please email it to me.
To Need help wiring manual fan on/off switch
