balanced flywheel
Old Apr 19, 2004 | 12:05 AM
DRM99CORVETTE's Avatar
DRM99CORVETTE
Default balanced flywheel
kind of new at the forum
Just a bought a flywheel that is stock for my spec stage 3, is the flywheel balanced. I has drill holes in it already but holes were in differant place then the flywheel that was on the car.
Thanks Pat :thumbs:
[Modified by DRM99CORVETTE, 5:06 AM 4/19/2004]
Old Apr 19, 2004 | 04:57 AM
C5kid's Avatar
C5kid
Cruise-In VI Veteran
St. Jude Donor '12
Default Re: balanced flywheel (DRM99CORVETTE)
just take it to a machine shop and make sure it is ZERO balanced. not worth the head ache to put it in and find out that it is off balance and have a vibration all the time......
Old Apr 19, 2004 | 12:01 PM
ArKay99's Avatar
ArKay99
Default Re: balanced flywheel (C5kid)
Actually, you need to have the new flywheel/pressure plate assembly balanced to the OLD flywheel/pp assembly, IF you have a stock rotating assembly.The stock rotating assembly is externally balanced at the front with the damper, and at the rear with the flywheel, if neccesary. If you have just the flywheel zero balanced and the old assembly was offset balanced as a counter weight, you will have vibration. :smash:
Old Apr 19, 2004 | 12:05 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: balanced flywheel (ArKay99)
I wouldn't trust a balanced clutch from SPEC if they gave it to me for free. Good clutches but often out of balance. Take it to the machine shop and have it Nuetral (0) Balanced....its worth the $20. The last thing you want is a vibration caused by an out of balance clutch.
Old Apr 19, 2004 | 11:41 PM
DRM99CORVETTE
thanks for the help guys!
To balanced flywheel
