Spark Plug Boot Shields
Old Apr 20, 2004 | 11:57 AM
INTHERED's Avatar
INTHERED
Default Spark Plug Boot Shields
When installing new plugs does it cause any problems if you leave the
metal shields off. It seems that the springs in the shields would tend
to push the boot off of the plug if it had a loose fit. I assume that the
shields are there for RF suppression not for ignition performance but
I could be wrong.
Old Apr 20, 2004 | 03:58 PM
texasredc8's Avatar
texasredc8
Default Re: Spark Plug Boot Shields (INTHERED)
I think those are heat shields, and you should keep them on there, or go with a 3rd party product called Kool-Socks (I think thats what they are called)
Old Apr 20, 2004 | 05:08 PM
IM4A2Z's Avatar
IM4A2Z
Default Re: Spark Plug Boot Shields (TexasRedZ06)
Ditto
Old Apr 20, 2004 | 05:10 PM
RyanC7's Avatar
RyanC7
Default Re: Spark Plug Boot Shields (IM4A2Z)
They are heat shields when you switch to headers you will see what they are ment for.
Old Apr 20, 2004 | 09:56 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: Spark Plug Boot Shields (Ryan2002C5)
Also used for static suppression shields for the sound system. I removed mine when changine plugs and wires, and immediately started getting static on weak stations. Re-installed, and static went away.
Old Apr 21, 2004 | 12:01 AM
AZGASSER's Avatar
AZGASSER
IMHO you can go with out them. I ran my stock wires with the Stainless Works LT headers and there was ample clearance. I now have Taylor racewires without Socks or Shields and better clearance and looks.
Old Apr 21, 2004 | 08:59 PM
Bob Chapman's Avatar
Bob Chapman
If in doubt keep them on.
Old Apr 22, 2004 | 08:44 AM
JohnnyO's Avatar
JohnnyO
Default Re: Spark Plug Boot Shields (Bob Chapman)
I kept them off for about 6,000 miles. When a plug wire (MSD) melted through and wouldn't fire the plug, I put them back on. Header heat from TPIS LTs
To Spark Plug Boot Shields
