Brake Fluid Advice Recommendations
Old Apr 23, 2004 | 12:42 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Brake Fluid Advice Recommendations (Black99Corvette)
Just make sure you are trying to solve the right problem. The low pedal you were getting is very indicative of pad taper Vs brake fade or boiling the fluid. The pedal on my 97 would go so low I couldn't heel/toe down shift. Bled the brakes like mad at the track and it never got better. Went home and installed new pads without doing anything else and pedal was right back where it should be.
Bill
