Injector question......
Old Apr 22, 2004 | 09:17 AM
bobsY2Kvette's Avatar
bobsY2Kvette
Default Injector question......
What pressure are the stock injectors on a 2000 a4 coupe. are 28 ponders an upgrade? Will it buy me anything in performance? Will i have to get re-tuned after the install? Anything else I should be aware of?
Bob
:seeya :seeya :seeya :seeya
Old Apr 22, 2004 | 01:53 PM
bobsY2Kvette
Default Re: Injector question...... (bobsY2Kvette)
TTT :skep:
Old Apr 22, 2004 | 02:08 PM
VetteDrmr's Avatar
VetteDrmr
Bob,
Unless you've done mods to flow more air through the engine, I don't think you're going to see any increases just by going to bigger injectors. The time you want bigger injectors is when you've got so much more air flowing through the engine (supercharger, bored&stroked, etc.) that the injectors are staying open more than probably around 80-85% of the time.
HTH, and have a good one,
Mike
Old Apr 22, 2004 | 02:20 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Injector question...... (VetteDrmr)
:iagree:
Adding 28# injectors on a stock motor that has 26# injectors will not gain any power. Your 36# injectors are not maxed out. Adding 28# injectors will require a rescale of your injector table.
Old Apr 22, 2004 | 03:35 PM
bobsY2Kvette
Default Re: Injector question...... (ICULUKN-C5)
thanks to all for the answer...I knew i could count on the forum for answers :grouphug: :seeya
Old Apr 22, 2004 | 10:45 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
I still use stock 26# injectors in my car with good results so for. :yesnod: :thumbs:
To Injector question......
