Help! Passenger window won't roll down
Old Apr 22, 2004 | 02:42 PM
Rainy99's Avatar
Rainy99
Default Help! Passenger window won't roll down
Anyone got any ideas? I can hear it has power, but looks like the motor will not roll the window down. Suggestions?
Thanks B
Old Apr 22, 2004 | 05:36 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Re: Help! Passenger window won't roll down (Rainy99)
One possible fix is to SLAM the door closed while holding the window button down. Do this a few times before you decide that it won't work. The motors have a tendency to corode if they aren't used periodically and slamming the door is sometimes enough to jar the brushes in the motor enough to find a clean contact point.
If that doesn't work then you will most likely need to replace the window regulator.
Old Apr 22, 2004 | 05:48 PM
Red Fish 5's Avatar
Red Fish 5
5th Gear
I had similar trouble where mine would not go up. It has limit stops in the door but when I stripped the whole thing out it was just the cables running stiff throughthe guides. I used a light oil spray and never had any trouble since. Mine is a 97'
Cheers
Old Apr 22, 2004 | 05:50 PM
Rainy99's Avatar
Rainy99
Thanks guys I will try the first...the door slam then open her up and have a look see.
I will report once I try the first.
Brennan
Old Apr 22, 2004 | 09:39 PM
Face's Avatar
Face
I have the opposite problem, mine rolls down on it's own sometimes. :confused:
To Help! Passenger window won't roll down
