Z06 rear brake duct Template??
Old Apr 25, 2004 | 03:59 PM
patmo's Avatar
patmo
Default Z06 rear brake duct Template??
Can some one please email me the Z06 rear brake duct templates?? patmo8@comcast.net
Thank you.
Old Apr 25, 2004 | 06:22 PM
IM QUIKR's Avatar
IM QUIKR
Default Re: Z06 rear brake duct Template?? (patmo)
Email sent
Old Apr 25, 2004 | 06:28 PM
simplyred02's Avatar
simplyred02
Default Re: Z06 rear brake duct Template?? (drcoffee)
If it's not too much trouble I would like a temaplate as well.
shawnc52000@yahoo.com
Old Apr 25, 2004 | 07:34 PM
ArmyVette's Avatar
ArmyVette
Can I get a copy of this template too? Looks like it'll be my next mod after some drivetrain upgrades.
jefferysmi@msn.com
Thanks.
Old Apr 25, 2004 | 08:40 PM
IM QUIKR's Avatar
IM QUIKR
Default Re: Z06 rear brake duct Template?? (ArmyVette)
When you print them, make sure you set the print option to NOT reduce to fit the page. Print from the File menu. Some programs will try to make it smaller to fit the page size and this will throw off the scaling. Once you print both pages, line them up on the cross-mark keys and tape them together. Cut out the template and check the fit against your ducts. If everything lines up, then transfer to cardboard or heavy paper. Use the same template for both sides of the car. Just flip it over. This way it will be lined up exactly the same on both sides.
http://www.baseframe.com/bill/matt_z06vent_template1.pdf
http://www.baseframe.com/bill/matt_z06vent_template2.pdf
Here you go boys. Download away. :cheers:
[Modified by drcoffee, 7:41 PM 4/25/2004]
Old Apr 25, 2004 | 08:42 PM
simplyred02
thanks!! :steering:
To Z06 rear brake duct Template??
