Best Header Bolts & Gaskets?
Old Apr 26, 2004 | 12:32 PM
Guest
Guest
Posts: n/a
Default Best Header Bolts & Gaskets?
Are the 'metal content' gaskets that come with the headers OK, or should I get copper gaskets or some other?
Old Apr 26, 2004 | 12:40 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: Best Header Bolts & Gaskets? (MMI)
Use stock gaskets, you won't find anything better and for header bolts go with www.go-breslin.com and you can buy these same bolts thru www.jegs.com :cheers:
Old Apr 26, 2004 | 08:28 PM
blackjack's Avatar
blackjack
I used factory gaskets and bolts with no problems. Lots of antisieze on the bolts too.
Old Apr 26, 2004 | 08:52 PM
Pumba's Avatar
Pumba
Don,
The Corvette LS1, not LS6 exhaust manifold gaskets are the correct parts to use.
I would suggest that you consider the ARP stainless steel header studs - www.arp-bolts.com/pages/products/pages/header/links/header_st.html . I have just installed them with my L.G. Motorsports Long-tube Pro headers and they outperform any bolt system I have ever used.
Good luck with you decision.
:seeya
Old Apr 26, 2004 | 09:06 PM
Guest
Guest
Posts: n/a
Default Re: Best Header Bolts & Gaskets? (runamuk)
That's what I'monna do. :thumbs: I hope it works. Thanks. :cheers:
To Best Header Bolts & Gaskets?
