Need Clutch Advice
Old May 1, 2004 | 08:56 PM
GTR#5's Avatar
GTR#5
8th Gear
Default Need Clutch Advice
Have 383 stroker puting out around 500HP. Stock clutch is toast at 20k miles. It currently hase the Chevy clutch w/aluminum flywheel. Looking for suggestions for a replacement. Thanks!
Dave
Old May 1, 2004 | 10:08 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Need Clutch Advice (GTR#5)
Exedy Twin Disc - here are a couple info links. Do a search of C5Tech recent and archive - a lot of info. :yesnod:
http://www.daikin-clutch.com/products/sports.shtml
http://www.daikin-clutch.com/products/PDF/Corvette.pdf
Good Luck!
Old May 2, 2004 | 09:21 AM
6Speeder's Avatar
6Speeder
If you are talking about 500 crank HP (about 425 rwhp), then the SPEC Stage II will work fine. I've been running one for 2 years, clamps hard, easy pedal, no chatter. If you are talking about 500 rwhp, SPEC makes a stage II/III combo for that power level. Others have reported continual chatter with the full stage III. :cheers:
[Modified by 6Speeder, 7:21 AM 5/2/2004]
To Need Clutch Advice
