How hard to change sway bars ?
May 2, 2004 | 11:50 PM
How difficult is it to swap out a set of front and rear sway bars ?
Is it possible without a lift ?
"D"
May 2, 2004 | 11:58 PM
Re: How hard to change sway bars ? (C5MongooseFL)
very easy and yes. maybe an hour job.
dave
May 3, 2004 | 12:01 AM
If you can put it on jackstands and turn a wrench, you can install swaysbars :cheers: .
May 3, 2004 | 12:06 AM
Re: How hard to change sway bars ? (jmzvet)
:thumbs:
May 3, 2004 | 12:08 AM
St. Jude Donor '03-'04
on a scale from one to ten its about a three maybe a two... it took me longer than an hour... but then I am old... maybe two hours tops... hell it takes me an hour to get it up..... the car, you sick bastards... :seeya
[Modified by Evil-Twin, 12:12 AM 5/3/2004]
May 3, 2004 | 12:12 AM
Re: How hard to change sway bars ? (Evil-Twin)
Or a Two :cheers:
I found this posted on here not too long ago. :thumbs:
http://www.c5howto.com/index.php?article=16
May 3, 2004 | 12:20 AM
Re: How hard to change sway bars ? (Sebring_C5)
When replacing the cheap endlinks witht the real metal ones... Pay attention to the holding tool used so that you can undo the nut without the entire piece spinning. On mine (1999) a torques bit (star) is used on the factory part. While the Z06 replacement endlink uses a hex key. :D
May 3, 2004 | 12:27 AM
Re: How hard to change sway bars ? (George8211)
Anyone have any Z06 sways they wanna get rid of ?!?
:cool:
Thanks for all the help guys !
"D"
[Modified by C5MongooseFL, 12:36 AM 5/3/2004]
May 3, 2004 | 12:47 AM
:withstupid:
2003 ,
2004 ,
bar ,
bars ,
c1 ,
change ,
changing ,
corvette ,
hard ,
replace ,
sway
