DTE Spring Open Dyno Day!!
Old May 3, 2004 | 04:27 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Default DTE Spring Open Dyno Day!!
We would like to welcome all members of the Corvette Forum for our third annual, Spring Open Dyno Day this coming Saturday, May 8th. from 8am-5pm. :party:
The cost for two pulls is only $40 and optional AFR graphing/measurement is a one-time charge of $15 additional. :)
This is a first-come, first-served event and in case you don't get a chance to get on the rollers during the alloted time, you can use the registration as a rain check and return for your dyno session at your convienence. :hurray:
Food, beverages and restroom facilities will be available throughout the day also for your convienence. :)
We usually are pretty busy with these events, so come early if you want to run your car to leave early. Even if you don't plan to run anything, it's still a lot of fun to watch many different types of cars screaming WIDE OPEN on the rollers! :auto: :steering:
Hope to see you all there!
Best Regards,
DTE
Old May 3, 2004 | 04:32 PM
wrustywrench's Avatar
wrustywrench
Default Re: DTE Spring Open Dyno Day!! (DynoTech Engineering)
Ill be there,,, wheeeeeeeee,,,,, :party: :party: :party: :hurray: :hurray: :hurray: :) :)
Old May 3, 2004 | 06:23 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Hmmmm... Sounds interesting. Maybe I can make it. :D
:seeya
Old May 4, 2004 | 07:17 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: DTE Spring Open Dyno Day!! (GTC)
Phil -sent an email....re:my car.
joel
Old May 6, 2004 | 12:30 AM
DTE Powertrain
Collections Hold
Default Re: DTE Spring Open Dyno Day!! (Bink)
t
To DTE Spring Open Dyno Day!!
