Battery Charging Problem
Old May 3, 2004 | 04:41 PM
LIGHTNING's Avatar
LIGHTNING
Default Battery Charging Problem
Just went to charge Delco AGM, which is completely drained since i left the key in ignition turned to "accessories" for 2 weeks....and when i plugged in charger, underhood light started blinking...clicking sound started...and whistling sound was coming from somewhere in engine bay. I quickly pulled plug...clicking stopped, light went off, but whistling continued....until i stepped on brake pedal. Everything was hooked up correctly. Any idea what's goin' on?
Old May 3, 2004 | 06:50 PM
Jimbad's Avatar
Jimbad
St. Jude Donor '06-'09-'10-'11
Default Re: Battery Charging Problem (LIGHTNING)
Just a guess as to why the battery will not recharge: it may be discharged beyond help. As far as the noises go let's hope some expert chimes is ( pun intended).
Old May 3, 2004 | 07:33 PM
Dave68's Avatar
Dave68
How many amps was the charger cranking out? The optimum charge rate for an AGM is 20 amps. If you juice the battery with too little, strange things can happen.
Old May 3, 2004 | 10:23 PM
LIGHTNING's Avatar
LIGHTNING
Default Re: Battery Charging Problem (Dave68)
15 amp charger. maybe that was the problem. Thanks!
Old May 3, 2004 | 11:25 PM
Dave68's Avatar
Dave68
I was thinking that you were using a 5-amp or less. I would try keeping the charger on for a while to see if the noises stop. I really doubt you can harm anything. With 15 amps, I'd say that the charger should be left on for at least a couple of hours. Of course, if it's an automatic charger, you won't have to worry about over-charging.
Good luck!
Old May 4, 2004 | 10:37 AM
carpe dm's Avatar
carpe dm
The key still on? :rolleyes:
To Battery Charging Problem
